i’m going to canada and alaska
and love to use my phone out there can you tell me step by step
what i need to do with my phone so that i can use my phone there so that it not going to be that much to use or that i do not go over my limit,
thanks
thanks
The following iD Mobile community articles might help:
I’d recommend the above from
https://www.idmobile.co.uk/help-and-advice/roaming-advice
It’s worth noting that Canada and the USA are not inclusive roaming areas therefore your allowances won’t be able to be used here, usage would be charged as extra.
Full charges can be found on the below link.
hi all
thank you so much for your help, i have a good look at all the links,
thanks again xx
