using my phone abroad
i’m going to canada and alaska
and love to use my phone out there can you tell me step by step
what i need to do with my phone so that i can use my phone there so that it not going to be that much to use or that i do not go over my limit,
thanks
The following iD Mobile community articles might help:
Hi @lucy2020
I’d recommend the above from @andewhite and the following article on roaming advice.
https://www.idmobile.co.uk/help-and-advice/roaming-advice
It’s worth noting that Canada and the USA are not inclusive roaming areas therefore your allowances won’t be able to be used here, usage would be charged as extra.
Full charges can be found on the below link.
hi all
thank you so much for your help, i have a good look at all the links,
thanks again xx
No problem @lucy2020
Perhaps a local SIM may be better for those countries not included.
