Data incorrect I dashboard and not rolling over
  • 3 September 2018
  • 229 views
Dashboard showing wrong data ie 5gb and should be 8gb and not rolling over contacted IDmobile , they said they would reply in 24-48hrs - haven’t
Best answer by Mobile1970
Solved at last - it appears IDmobile got it wrong - they have now put the correct data for my plan and rolled over. I await next months bill to see if it stays corrected.
thanks for your reply
  • September 6, 2018
Hello @Mobile1970,
The iD app always reports the most up to date allowance which goes off your account.
Have you just joined iD Mobile or have you recently upgraded/changed plans?
Are you saying the app is reporting this incorrectly as data has not rolled over?
  • September 6, 2018
  • September 7, 2018
Glad to hear it's been solved for you @Mobile1970 !
Thanks for confirming that here.
I've marked this as solved.
Reply.
