H+ not 4g
Have just switched to idmobile from O2 which always connected to the internet using 4g on my Samsung galaxy j5. When using the SIM card from idmobile the phone will only connect using h+ which is much slower. How can I get it to use 4g instead?
Best answer by Mohammed
Hello @Sarahjn ,
Each network's coverage can vary.
Whilst you may be used to O2's 4G coverage, iD Mobile's coverage can also vary.
Have you tried checking your coverage on: https://www.idmobile.co.uk/help-and-advice/uk-coverage-checker
This will give you an indication on the expected levels of 4G.
View originalEach network's coverage can vary.
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
