New IPhone 6 sends texts in triplicate - each text is sent 3 times and tells me that the text is undelivered. Have turned the phone off and back on again, taken sim out and put it back and have reset network settings. Can’t use 7777 - lnog story. Any suggestions/help would be appreciated. Suspect this is a rare problem.
Multiple text problem
Best answer by Mohammed
Let us know how you get on.
In some cases, the issue relates to mostly iMessage and not having the correct number in place.
1) Try turning off iMessage (Settings > Messages)
6) Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:”.
