Im having issues roaming. I followed the guide to roaming so Data roaming is enabled on app and handset. I have full reception on Movistar 3G and an R next to it so I know it should work. But I cannot get on the net or send texts or use apps like gmaps. Anyone had this experience before? If I had no reception I would understand but there is full connection. WiFi all works fine so it's not a handset issue. I've turned handset on and off several times, same for settings. My wife has the same problem, shes also on ID! Any ideas anyone? Thanks.
Roaming Problems in Mallorca
Best answer by Mohammed
Hello @trg ,
Sorry to hear you're having issues.
Are you referring to this topic: How to prepare your phone for a trip abroad
There's a second post as a reply below this I added later.
This advises you'll also need to make sure the correct Access Point Names are configured.
Can you send me a screenshot of your APN settings?
View originalSorry to hear you're having issues.
Reply.
