Top tips to spring clean your phone.
  • 23 February 2024
  • 84 replies
  • 24601 views
Cull your contacts
Organize your home screen
Get rid of unused apps
Delete photos and videos
Turn off location tracking
Clear your cache
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
Good luck!
Just keep on top of cleaning all year round...
Just sweep it under the rug as ID Mobile do with competitors!! :D
Use newspaper to clean windows.
Fill your kitchen sink with warm water and soda crystals then pop in your cooker hood grease filters- you will watch them go from brown to silver before your eyes and all the stickiness will be gone, no scrubbing needed! Use it also to wipe down your cooker hood top which can get all sticky and it will glide off!
Usually the first thing i do is clean the curtains,then the windows and finally the entire upper parts of the furniture.
Userlevel 2
Use it as an opportunity to declutter as you go. Choose a sunny day and it really shows up the dirt. Hiring but job well done
Get someone else to do it!
Life’s too short
Get all those pesky cleaning jobs out of the way during the winter, so when spring comes you can forget about them and spend time enjoying all the things you love
Recycle old socks to use as dusting mitts.
Anything not used for 12 months, recycle, charity shop or tip.   In the space created hide more junk and clothes.  Repeat next year!
Use bicarbonate of soda solution with kitchen cleaner to get rid of grease on glass surfaces. Wipe and finish using newspaper to get an even shine on the glass.
Take the extra few seconds to Load the dishwasher properly, you’ll have clean dishes first time and they should dry as well.
Switch it off and then on again. This will close down all your apps and clear the memory and should make your computer work a little better
Don’t clean very often, then at least it’s worth it when you do!
White vinegar and some newspaper to clean your windows and mirrors with a streak free finish! Good old free Metro always does a great job!
My hack:
1. Sweep the floor
2. Mop the floor
3. Repeat if you forgot to contain your pets during the process
I'm sure my hack would be more interesting if I had this EUFY RoboVac 15C. 😉
Drag the oven out of its’ cubby and give it a good clean.
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
I always put a washing pod in the mop bucket water, smells amazing and helps with the cleaning.
I like to put a washing pod in the mop bucket it smells amazing and helps with the cleaning
Restore the finish on your brushed stainless steel balustrade with an abrasive stainless finishing pad (fine) available Amazon or similar.
Run the pad the same direction as the existing grain and they come up like new. Only light pressure and small amount rubbing required.
I use natural cleaners, such as bicarbonate of soda, white vinegar, soda crystals and lemon. They clean effectively and are better for your health and the environment. It’s a win win situation.
why wait for spring 😀
Don't wait until Spring
Userlevel 2
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
Little and often is the way to go
Order a skip, cover your eyes with blindfold and start throwing things from the house until skip gets full. Simple Cleaning Solution
