Top tips to spring clean your phone.
  • 23 February 2024
  • 84 replies
  • 24671 views
80% found this helpful
Show first post
  • 9 replies
  • March 1, 2024
Just keep on top of cleaning all year round...
Dawid Lis
  • March 1, 2024
Just sweep it under the rug as ID Mobile do with competitors!! :D
Johnacampbell
  • 18 replies
  • March 1, 2024
Use newspaper to clean windows.
Allie T
  • March 2, 2024
Fill your kitchen sink with warm water and soda crystals then pop in your cooker hood grease filters- you will watch them go from brown to silver before your eyes and all the stickiness will be gone, no scrubbing needed! Use it also to wipe down your cooker hood top which can get all sticky and it will glide off!
Renata Rinelli
Usually the first thing i do is clean the curtains,then the windows and finally the entire upper parts of the furniture.
  • 34 replies
  • March 2, 2024
Use it as an opportunity to declutter as you go. Choose a sunny day and it really shows up the dirt. Hiring but job well done
Max Stanton
  • March 2, 2024
Get someone else to do it!
Life’s too short
Horlicks
  • March 2, 2024
Get all those pesky cleaning jobs out of the way during the winter, so when spring comes you can forget about them and spend time enjoying all the things you love
  • 6 replies
  • March 2, 2024
Recycle old socks to use as dusting mitts.
  • 14 replies
  • March 2, 2024
Anything not used for 12 months, recycle, charity shop or tip.   In the space created hide more junk and clothes.  Repeat next year!
  • March 2, 2024
Use bicarbonate of soda solution with kitchen cleaner to get rid of grease on glass surfaces. Wipe and finish using newspaper to get an even shine on the glass.
  • 11 replies
  • March 2, 2024
Take the extra few seconds to Load the dishwasher properly, you’ll have clean dishes first time and they should dry as well.
  • March 2, 2024
Switch it off and then on again. This will close down all your apps and clear the memory and should make your computer work a little better
  • 16 replies
  • March 2, 2024
Don’t clean very often, then at least it’s worth it when you do!
  • March 2, 2024
White vinegar and some newspaper to clean your windows and mirrors with a streak free finish! Good old free Metro always does a great job!
  • March 2, 2024
My hack:
1. Sweep the floor
2. Mop the floor
3. Repeat if you forgot to contain your pets during the process
I'm sure my hack would be more interesting if I had this EUFY RoboVac 15C. 😉
  • 12 replies
  • March 3, 2024
Drag the oven out of its’ cubby and give it a good clean.
Vicky Lawler
  • March 3, 2024
Nikhil P wrote:
Cull your contacts
Organize your home screen
Get rid of unused apps
Delete photos and videos
Turn off location tracking
Clear your cache
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
Good luck!
I always put a washing pod in the mop bucket water, smells amazing and helps with the cleaning.
Vicky Lawler
  • March 3, 2024
I like to put a washing pod in the mop bucket it smells amazing and helps with the cleaning
  • March 3, 2024
Restore the finish on your brushed stainless steel balustrade with an abrasive stainless finishing pad (fine) available Amazon or similar.
Run the pad the same direction as the existing grain and they come up like new. Only light pressure and small amount rubbing required.
  • 32 replies
  • March 3, 2024
I use natural cleaners, such as bicarbonate of soda, white vinegar, soda crystals and lemon. They clean effectively and are better for your health and the environment. It’s a win win situation.
  • March 3, 2024
why wait for spring 😀
Alan Wickham
  • March 3, 2024
Don't wait until Spring
  • 18 replies
  • March 4, 2024
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
Little and often is the way to go
  • March 4, 2024
Order a skip, cover your eyes with blindfold and start throwing things from the house until skip gets full. Simple Cleaning Solution
