Not receiving calls and can't make outgoing calls
i am having problems with receiving and making calls, one day it will be ok and then can’t do either for several days, i have rebooted my phone several times, all the settings are the same, is this an ID network problem or something else?
Ron
Best answer by Kash
Hi @Derbyron,
It sounds like it may your handset settings.
Have you tried to enable 4G and Volte then disable 3G.
The Community post below may help.
  • May 22, 2024
Hi @Derbyron,
  • May 22, 2024
I have managed to get it working again by turning on the alerts in notifications for the phone, not sure how it managed to get turned off in the first place though
  • May 27, 2024
Hi @Derbyron
Glad to hear that’s helped.
