not ringing
Steed Pullen
For a few weeks now, I am rarely able to make calls, when calling someone it says calling on the phone but there’s no ring tone and then after a while it says call failed, also people are for the most part not able to ring me as it either doesn’t ring my phone or goes straight to voicemail.
Okay @Steed Pullen, are you in the Midlands area shown below?
  • May 15, 2024
Steed Pullen
No
Steed Pullen
Anyone????
  • May 21, 2024
Hey there @Steed Pullen, welcome to Community!
We’re sorry to hear this. Please note, on Community, our response times will vary, so if you’d like an instant response, we’d recommend contacting via live-chat:
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please let us know, and we can investigate further.
Kind regards,
  • July 8, 2024
Won’t let me ring out keeps saying call failed and I can’t speak to 3 about if the network is down
  • July 22, 2024
Hey there @Beckyp23, we’re very sorry to hear that. In that case, please contact our live-chat ASAP to have this investigated further:
Rebecca M
Forum|alt.badge.img
  • January 10, 2025
Did you get this sorted by any chance? I have been having the same issue and it’s really stressing me out. Thanks, any help will be appreciated
  • January 11, 2025
Hey there ​@Rebecca M, we’re very sorry to hear that. For the fastest guidance, pllease contact our live-chat ASAP to have this investigated further:
