Outside Eu Travel Question
  • May 18, 2024
  • 132 views
Papacled
Planning to go to the Maldives, but can't find info on places that aren't in the category band 1 or band 2 locations.
We will be going via Doha, then onto Maldives.
1. Will ID mobile even work for signal in both locations?
2. If data turned off, would there be a charge for call/text or even just being outside the EU?
3. Would roaming need to be turned on or off? As in what's the difference?
Thank you
Best answer by Kash
Hi @Papacled,
We do offer network partners in both locations. Whilst in Doha please connect to Ooredo and Wataniya in Maldives.
If you don’t wish to be charged I would advise reducing the cap to £0 and turning roaming off.
  • 8064 replies
  • May 21, 2024
Hi @Papacled,
