switch my plan
  • November 29, 2024
  • 51 views
Malcolm3321
Hi I want to switch to a sim only £8 deal
The iD telephone sales team should be able to help you change your plan, ​@Malcolm3321
Contact the sales team on 020 7139 1397 between 9am - 6pm.
  • 12065 replies
  • November 29, 2024
Malcolm3321
  • November 29, 2024
No use as they cannot replace the sim with the same number??
Said call ID
Even though they are???
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 431 replies
  • November 29, 2024
If you want to retain your number you need to leave ID, and find another provider.
Then get a PAC from new provider, and switch back to ID with your number.
  • 8058 replies
  • December 2, 2024
Hi ​@Malcolm3321
I’m not sure what you mean here, if you wish to switch your plan you’ll be able to look into the app to make a plan change or an upgrade, or call the sales team.
This is if you’re eligible for a plan change or upgrade on your existing plan.
If you’re purchasing a new plan, it isn’t possible to directly move a number from iD Mobile to another iD Mobile plan.
