cant call Europe
Chris Coatsworth
I've tried calling Spain and the message says my plan does not allow this...how can I sort this?
MZone
Gold Contributor
Forum|alt.badge.img+18
  • Gold Contributor
  • 673 replies
  • March 25, 2025
Have you got a spend cap or a bar? Check your settings on the app.
  • 3294 replies
  • March 26, 2025
Hey there ​@Chris Coatsworth, sorry to hear that.
Are you trying to call someone in Spain whilst you’re within the UK?
Chris Coatsworth
Yes Tyler I am...never had any issues before but this is the first time using ID Mobile since I switched
  • 3294 replies
  • March 27, 2025
Hey ​@Chris Coatsworth, you will need to ensure you’ve enabled international and roaming settings via both the iD Mobile app/website, and also ensure your bill cap is high enough to allow for charges to go through.
Chris Coatsworth
Did all of that without success.
I've sorted the call using a freinds network.
All of my settings are correct so really don't know what else to do.
Thanks for your advice tho
  • 3294 replies
  • March 28, 2025
Have you been able to call this number on our network before?
We’re glad to hear your friend could help!
