Jun 21, 2026 3:16 PM UTC
data loyalty add on problem help
Hi, it says I have an unlimited data loyalty add on but have received a text to say I’ve run out of the amount in my plan and details of how I’ll be charged going forward. That doesn’t add up to the loyalty add on. Please can I have some advice on this. Thanks.
    Jun 22, 2026 1:03 PM UTC
    Hi ​@Ukulele81,
    We'll speak to you there.
    Jul 16, 2026 9:21 PM UTC
    Hi, I’m also having the same problem currently
    Hosai W
    Jul 17, 2026 8:54 AM UTC
    Hi ​@Tabathax3,
    I'll speak to you there.
    Hosai
    Oct 18, 2026 6:13 AM UTC
    I also get this issue and have the loyalty unlimited add on. It’s annoying! Is there a way to stop it?
    Oct 18, 2026 6:32 AM UTC
    Hi ​@Oliviajm,
    I'm sorry for the frustration.
    Unfortunately, those warning texts can't be turned off. However, if you have the Loyalty Unlimited Add-on, once you've reached your allowance, the add-on will automatically kick in.
