Rewrapped and ready: why refurbished phones are worth a look.
A shiny new phone doesn't always have to come with a shiny new price tag.
Between presents, food, and festive days out, Christmas can get expensive. Luckily, refurbished phones offer a handy way to get premium features and great value, while giving perfectly good tech a second lease of life.
Why refurbished makes sense during the holidays.
The biggest perk is simple: you can often get more phone for your money.
A refurbished flagship from a year or two ago could give you access to premium features for the same budget as a brand-new mid-range handset. That means a great camera, sharp display and plenty of power for everyday use, making it a smart choice if you're looking for quality and value.
And there's another benefit: keeping existing devices in use for longer helps reduce electronic waste and the demand for new raw materials. Handy for your wallet and the planet!
Learn what "refurbished" actually means.
You might see the words used, second-hand, pre-owned and refurbished popping up when you're shopping for phones. They sound pretty similar, but there's a difference.
A used or second-hand phone is generally sold in its existing condition. A pre-owned phone simply means it's had a previous owner. Neither term tells you how thoroughly it's been checked.
Refurbished is a little different: these phones have usually been professionally inspected, tested and cleaned before being sold again.
You'll often see refurbished phones grouped into condition grades. These describe their cosmetic appearance, not how well they work. The exact descriptions vary between retailers, but here's a general guide:
| Grade | What you can expect |
| Excellent | Little or no visible wear. Likely to look almost new. |
| Very Good | Minor signs of use, such as light scratches. |
| Good | More noticeable scratches and scuffs, but fully functional. |
Don't automatically dismiss a phone because it's graded ‘Good’. If you're planning to put it in a protective case anyway, a few marks on the casing might not bother you at all. Plus, choosing a lower grade can mean paying less for exactly the same features. Just check the retailer's grading guide before buying, as the descriptions aren't universal.
Key things to check before you buy.
Found a phone you like? Before you make a decision, there are a few things worth looking into.
Warranty and returns. Check how long the warranty lasts and what's covered. It's also worth reading the returns policy, so you know where you stand if the phone isn't quite what you expected.
Network compatibility. Make sure the handset supports the network technology you need. Most modern smartphones support 4G, while newer models may also offer 5G. Check that your chosen phone works with your network.
Storage. If your camera roll is full of holiday snaps, videos and screenshots you really should delete, storage matters! So look at the capacity before buying, especially if you download lots of apps or games.
Battery health. Smartphone batteries gradually lose capacity as they age, so find out whether the battery has been tested and if there's a minimum battery-health guarantee.
The retailer. Buy from somewhere you trust. iD Mobile's refurbished phone range offers professionally checked handsets, while Currys refurbished tech has a wide range of tested devices available.
A second chance that’s worth unwrapping.
Refurbished phones are worth considering if you're after an upgrade without the brand-new price tag. You can find some great older models that still have plenty to offer, and choosing one helps keep useful technology in circulation for longer.
At iD Mobile, you'll find a wide selection of refurbished Apple and Samsung devices, including former flagship models that still deliver excellent performance, cameras and features. So whether you're after a premium handset or simply looking for great value, there's plenty to explore!
Have you bought a refurbished phone before, or are you thinking about getting one this Christmas? Let us know in the comments below!
