2 factor authentication code
I recently switched to ID mobile from another network carrying my old number over. However I am now unable to receive 2 factor authentication codes sent via SmS
Best answer by MZone
If you're not receiving 2-factor authentication (2FA) texts, it could be due to a few reasons: incorrect phone number entry, your phone blocking unknown numbers, network issues, carrier blocking such messages, a problem with the service you're trying to access, or a faulty phone setting related to SMS delivery; check your phone settings to ensure you're not blocking verification texts and try restarting your phone or trying your SIM in a different phone to see if that resolves the issue.
What handset are you using?
MZone
Gold Contributor
Forum|alt.badge.img+20
  • Gold Contributor
  • 840 replies
  • March 5, 2025
  • March 5, 2025
Thank you. I switched off spam blocker in call settings which seems to have solved the issue!
MZone
Gold Contributor
  • Gold Contributor
  • 840 replies
  • March 5, 2025
Glad it got sorted for you.
  • 8182 replies
  • March 5, 2025
Hi ​@ElliottGal
Glad to hear it was a simple fix.
