Data plan in Canada
I'm going to Canada in July and have seen some Q&A on here re roaming charges and calls etc but can anybody tell me - can you purchase additional data before you leave the UK and can non-wifi Internet use come out of that or does the data within your plan/purchased in advance not count in Canada? Thanks
You can’t buy an iD add-on for roaming in Canada, @Lesley McG
You’d be charged as follows for roaming with your iD SIM in Canada:
  • 12167 replies
  • May 31, 2024
  • May 31, 2024
@andewhite - thanks for the reply. I wasn't sure if it was worth buying extra data if I then couldn't use it. I'll just stick to public WiFi!
  • 8175 replies
  • June 5, 2024
Hi @Lesley McG,
It looks like @andewhite has answered your query.
