Help - not receiving verification codes via Text
  • April 21, 2026
  • 69 views
I have recently moved from EE to ID mobile and seem to be having issues receiving verification texts. I spoke with someover over live chat and did all the things they recommend with no luck. I am at a loss now, having tried everything, and really need access to these apps as it’s for banking. Has anyone had this issue and how was it resolved? Any help appreciated as I don’t seem to be able to speak to a person over the phone. Not a great first impression for ID Mobile.
    Lamiya C
    Hi ​@H777 ,
    I’m really sorry you’re having this issue, especially as it’s affecting access to your banking apps.
    This is quite common after switching networks and is usually due to a partial port or messaging sync issue.
    Please try the following:
    • Restart your phone and reinsert the SIM
    • Make sure your number is set correctly in Settings > Phone > My Number
    • Turn Airplane Mode ON for 10 seconds, then OFF
    • Ensure iMessage/RCS is turned off and back on (if applicable)
    Important:
    Verification (OTP) texts can sometimes be delayed after a number transfer, even if normal texts work.
    If you’ve already tried these steps and it’s still not working, this will need to be escalated as a porting/SMS routing issue on our side.
    Let us know.
    Lamiya
    H777Author
    Hi Lamiya,
    Thanks for your response. I have tried this and still no luck. I would appreciate if you could escalate and get back to me as a matter of urgency.
    Hannah
    Hi ​@H777
    I'll speak to you there.
    Michael Z
    Hello I need to know if there’s any fix for this I am currently going through the same issue
    Owethu M
    Hi ​@Super345
    I do apologise that you unable to receive OTPs. Please check if the number under settings is showing correctly:
    For iPhone:
    - Please go to Settings> Phone> My Number.
    - Please change it to the number you wish to keep. It might not allow to change or save immediately.
    - If the number does not change kindly open the Settings app. Tap General. Scroll down to the bottom of the list. Tap Reset. The "Reset" option is at the bottom of the Settings menu. ... Tap Reset Network Settings. Enter your passcode if prompted, then tap Reset Network Settings to confirm your choice. This will help.
    For android:
    To check or update the number shown on your Android device, please follow the steps below:
    📱 Check your phone number in settings
    1. Go to Settings
    2. Tap About Phone or About Device
    3. Select Status
    4. Tap My phone number
    📌 On some devices, this may appear under SIM Status or SIM Card Status within the Status menu.
    💬 Update number in Messages app (if applicable)
    If your number is showing incorrectly in messaging:
    1. Open the Messages app
    2. Tap More (⋮)
    3. Select Settings
    4. Tap Advanced
    5. Select Phone number
    6. Enter the correct number associated with your SIM
    7. Tap OK to save
    🔄 If the number is still incorrect
    * Remove the SIM card
    * Restart the device
    * Reinsert the SIM card
    * Check again in Phone Settings
    🔍 Further troubleshooting
    If the issue persists after rebooting:
    * Insert the SIM into a different device
    * Send a text message and check whether it displays:
    - Your correct (ported) number, or
    - The temporary number
    This will help determine whether the issue is with the SIM or the handset.
    Owethu
