how do i send my PAC code - to keep my existing number
  • May 31, 2026
  • 68 views
How do I send my PAC code to keep my existing number - appears far from straightforward
    Geluk
    Silver Contributor
    Silver Contributor
    May 31, 2026
    It’s very straightforward if you follow instructions when you log in; When your 1pMobile SIM arrives, log into your account and activate your SIM.
    Follow instructions in letter sent with your 1P SIM, using ACTIVATION CODE provided.
    Hi ​@Ossiedog
    I'll speak to you there.
    Zandile m
    The iD Mobile Team
