Im ready to upgrade need help?
  • March 25, 2026
  • 52 views
I can upgrade now but it says I can only get a iPhone 17 what do I do when I wanna get a iPhone 17 pro max??
    iD Support
    Hi ​@Milt04
    Thank you for getting in touch with us.
    If you are only seeing the iPhone 17 available when trying to upgrade, this usually means that the iPhone 17 Pro Max is currently not available on your specific upgrade path or is out of stock for your account at this time.
    I understand you would prefer the Pro Max model. In this case, you can:
    Check again under “Change device” or “Upgrade to a different handset”
    Sometimes the Pro Max options are shown in a separate section rather than the main upgrade page.
    Alternatively, please contact our Sales Team on 0800 049 0250, and they can manually check availability for you and advise further.
    Zandile M
    The iD Mobile Team
    Need to find out about iphone17 deals
    Owethu M
    Hi ​@Zaki AHMADI
    Please reach out to our sales team via Live Chat or contact via number 0800 049 0250.
    They will be happy to assist.
    Owethu
