I have just joined ID mobile and whenever i receive an incoming call it is really quiet and muffled (sounds like they are underwater). But if i make an outgoing call the sound is clear. Not happy about this as i’ve just switched to id
incoming calls muffled but outgoing calls fine
Best answer by Tyler
Hi there
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please let us know.
Also, please try the SIM card in another phone to see if the issue persists. If it doesn’t, then it could possibly be a device issue.
Log in to the iD Community.
Social Login
Log in with FacebookPlease note: From 31st July 2025, you'll no longer be able to Log in with Facebook. To keep using the iD Community, you'll need to create a password. Click 'Forgot Password?' to get started.
