Issue with WIFI calling at work
  • May 2, 2025
  • 6 replies
  • 109 views
I changed to a newer phone a couple of weeks ago (iphone 7 to iphone 12) and have been having problems getting and making calls when at work.  There is very little signal in the building so the phone uses wifi calling when I’m in the office which worked fine before - I’m using the same SIM card as previous.  I have checked when at home and WIFI calling works fine there (put on airplane mode to check) so it is just when on the work WIFI that it does not.  Tried called over Whatsapp at work and this works ok.  Not sure what to try after that - if I cannot get it working I will need to change provider as I cannot  continue with not being able to use phone when in the office.
    Siân W
    Hi ​@lreed7619  sorry to hear this. There may be a fix in your settings.
    In ‘settings’, ‘phone’ (under iOS 18 its under ‘Apps’, ‘phone’) ‘My Number’ may be blank. Once corrected and phone restarted, the Wi-Fi calling should start working perfectly. Please let us know how you get on.
    lreed7619Author
    Phone number is already in and I’ve tried replacing it but not made any difference
    Thank you for confirming ​@lreed7619
    Does your number show as +44 at the beginning? If not, are you able to amend it to this?
    For example +447891234567.
    Natalie
    lreed7619Author
    Yes it is and WiFi calling works when in the house just not when at work
    Siân W
    OK ​@lreed7619  have you checked this with your work at all? Could it be possible they have restricted the Wi-Fi use?
    I have exactly same issue but at home. Tried all tips. Putting it in airplane mode works but can’t be doing that all day and I’m missing important texts from my elderly mum.  It only started when I went to Idmobile.  My iPhone is new, 16.  Tried raising loads tickets. Went into Currys. Got new sim.  Tried everything.  Pls can Idmobile answer this one! Currys Scunthorpe tried very hard to no avail.  Currys Canary Wharf were very rude and tried to tell me my wifi calling was switched off!  Help.
