issues with SMS iPhone 16 pro max
  • August 14, 2025
  • 97 views
Has anyone got an iPhone 16 pro max using id mobile and experienced issues with SmS messages?
The phone can send an sms but then afterwards I get a message saying the message failed to send even though it was received by the recipient. I can’t however receive text messages.
I’ve followed all advice from Apple and Dr Google to no avail and even done a hard reset.
ive tried the sim in another iPhone but the same results occur. ID mobile fobbed me off to Apple the other day so before I go back to them tomorrow, has anyone had similar issues?
    Best answer by WelshPaul
    If you’ve tried your existing SIM card in a different handset and the issue persists, consider ordering a replacement SIM.
    WelshPaulAnswer
    Hi ​@davidwn2
    Sorry to hear this, was the SIM card in your device before your number transferred?
    It’ll be worth visiting the below page to see if the steps there help;
    If not, as ​@WelshPaul suggests, a replacement SIM would be next best to try.
