Mobile calls being forwarded to landline
Hello, we’ve had digital voice installed but if someone calls me on my mobile phone & I can’t answer the call the caller gets diverted to my landline phone number. How can I stop this? This has only happened since digital voice was installed. There is no call diversion/forwarding set up on my mobile phone. Thanks
Best answer by MZone
Your landline and mobile are 2 separate products. The only way your mobile calls will divert to another number is if you set up call forwarding on your mobile to that number.
MZone
Gold Contributor
Forum|alt.badge.img+20
  • Gold Contributor
  • 849 replies
  • March 5, 2025
  • 8182 replies
  • March 5, 2025
Hi ​@SallyG25
I’d recommend checking your device settings, call forwarding is set up there.
