my phone is not fit for purpose
My phone IPhone { REMOVED } is causing me major issue. It keeps overheating, duplicating contacts every day, freezing contact and dial the buttons. It also won’t show me who has called and sometimes it doesn’t ring or rings, but you cannot answer it. It even deletes important contacts like my family.
I have had back and forth conversations with apple and their technician has deleted all contacts and I manually reinstalled them one by one. The contacts are already duplicating again.
I have let apple know deleting the contacts has not worked. I am frustrated and at a loss. Please can you advise if there is anything you can do from your end to check.
Many Thanks
samantha Brailsford
