phone call issue
  • October 24, 2025
  • 45 views
When I type in a number and press call - the call doesn’t ring it just say “call ended”
This isn’t with every number just some!
    Hi ​@Barbs1987
    Sorry to hear that, can you confirm if you are able to receive calls with no issues?
    Michael Z
    Barbs1987Author
    yes I can receive calls.
    JoeKing
    Silver Contributor
    Silver Contributor
    October 24, 2025
    @Barbs1987  Hi there check to see if there any reported faults, on-going work for the post code area unless this is happening it different location.
    I've experienced this in the pass and it's been a network problem. Sometimes these aren't update on the website in real time even when they have been report.
    Secondly try your sim card in a known working phone to see if the problem is still happening.
    ID Mobile network checker
    Joe 😃
