Hi all, can anyone confirm if I can port my number (using PAC code) from 3 network to ID mobile? I have see some good deals offered by ID Mobile but the 3 guy tells me that I will not be able to port my number as they are on the same network (3)?
Porting number from 3 to ID Mobile
Best answer by MZone
Of course you can. Although iD use Three as a network partner they are completely different. Don’t listen to Three they just don’t want to lose you as a customer. Just request a PAC code from Three. I myself am an ex Three customer and kept my number when transferring to iD.
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
