How can I check that my wifi is working on my Samsung Galaxy A41 android phone. I have 80 GB of data
Set up wifi on samsung galaxy A41
Best answer by Kash
You can connect to Wi-Fi via your settings and it will show the Wi-Fi icon below when successfully connected
If you are referring to 3G/4G/5G you will see the icon in the top corner of the screen.
You may need to turn mobile data on via your settings for it to work.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
