travelling to vegas
  • September 11, 2024
  • 79 views
Denise Moore
Just realised my id mobile sim won’t work in Vegas, can you advise best sim to get for data usage please? iPhone 12
Best answer by Tom
Hi @Denise Moore
You’ll be able to use your iD Mobile SIM card while in the USA, however it would cost extra depending on the usage made.
It could be best to while in the USA pick up a Pay As You Go SIM card.
  • 8225 replies
  • September 12, 2024
Hi @Denise Moore
