trouble setting up voicemail pin
  • May 21, 2026
  • 64 views
Hi I’ve tried all the suggestions for setting up voicemail pin but still getting the same message to call for set up.
    Best answer by Lamiya C
    Hi ​@AbiW21 ,
    Sorry to hear you’re still having issues setting up your voicemail PIN.
    Please try the following quick steps:
    Dial 123 from your iD Mobile SIM
    When prompted, follow the voicemail setup options fully
    If it asks again to call for setup, dial 1755 instead to access voicemail settings directly
    Restart your phone afterwards and try again
    If it still doesn’t work, let me know and I’ll get this checked further for you.
    Lamiya
    Lamiya C
    Lamiya CAnswer
    Hi ​@AbiW21 ,
    Lamiya
    AbiW21Author
    Hi & thank you. Dialled 123 & managed to set everything up & access my voicemails so all sorted 😊
