Urgent - Split port issue, can make calls and send texts, but not receive calls
I'm having the same issue as this post below whereby I have had my number ported over today from Talkmobile to ID mobile (22nd October) and I received a text to say number swap was complete. However now I can make calls and send texts and receive calls from ID mobile numbers, but I cannot receive any other calls or any texts.
I’m I hadn’t put my ID mobile sim into my phone as I didn’t want to associate the temp number to it as it’s a pain to remove after it swaps over. I only put my sim into my old phone after the porting was complete. I still need to set my new phone up as I was away at the weekend.
I have been onto chat help for ages and checked all the settings they’ve suggested and even been to Curry’s and got a different sim as they suggested. This still hasn’t changed anything. When I try off another phone it just says number not recognised please check and try again.
I think someone highlighted the post to ID support here for the OP in the link. Try to reply on there but it hasn’t gone on, not sure if this is because it is solved or not.
Thank you
