can i use my phone in Kos on my dataplan?
Hayley Nicola Doughty
Can I use my data plan in Kos without incurring charges?
Kos is part of Greece, which is one of the inclusive EU roaming destinations, @Hayley Nicola Doughty
Assuming your iD account and handset allow roaming mobile data, you should be able to use your iD plan data allowance in Kos without extra charges.
These forum articles explain how to roam using your iD SIM card.
  • 12619 replies
  • June 3, 2024
  • 8765 replies
  • June 10, 2024
Hi @Hayley Nicola Doughty
As suggested above by @andewhite, yes, you’ll be able to use your plan while in Greece/Kos.
It may be worth checking the following to see how much data you’ll get.
