Jul 3, 2026 3:04 PM UTC
help please with my next bill
i need help
my first bill was on the 28th
i changed it to the 2nd of every month, its now says it will come out next month not this month so will it charge me for this month?
    Jul 3, 2026 6:06 PM UTC
    Hi ​@iilexn,
    Thanks for getting in touch.
    When you change your Direct Debit payment date, the change doesn't take effect immediately. It applies from your next billing period, so if there was already a payment due, it would still be collected on the original date.
    Because your billing period has changed to align with your new payment date of the 2nd, your next billing month will be longer than usual. During this extended billing period, your line rental and allowances are pro-rated, which means your next bill will likely be higher than normal as it covers a longer period.
    Your Direct Debit may also be taken up to 3 working days after your nominated payment date due to the Direct Debit process.
    iilexnAuthor
    Jul 3, 2026 10:11 PM UTC
    this is what it says on my bills so will it go out on that date or will it come out for this month as ive not paid this month.
    Hosai W
    Jul 6, 2026 8:19 AM UTC
    Hi ​@iilexn,
    I'll speak to you there.
    Hosai
