Lanzarote question
  • 29 June 2024
  • 199 views
Hi,  Going to Lanzarote on Monday.  i have a sim only deal.  will i be charged using my mobile whilst there.  I have 399gb rolled over.
Lanzarote is an inclusive roaming roaming destination, @Rwj1968.
You can use your UK plan allowances out there, but your roaming mobile data may be limited to 30GB/month, depending on when you joined iD.
Thank you andewhite
Hi @Rwj1968
Roaming while in Lanzarote (Spain) is inclusive to your plan.
We’d recommend checking the below for how much data you’ll be able to use while roaming;
