DATA ROAMING NOT WORKING IN FRANCE
Data is not working in France. I can make phone calls and send text messages but I’m unable to use data. Can anyone advise on how to fix this issue?
Best answer by Tom
Hi @Benble
I’d recommend trying the following;
  • March 25, 2024
Did you find a solution as have the same problem
  • 8083 replies
  • March 29, 2024
Hi @Steelmen91 @Benble,
Whilst in France please can you try and connect to the following networks BYTEL/BOUYGTEL, Free Mobile and Orange.
Can you also confirm which make and model handset you are using?
It may also be worth double checking that roaming is enabled on the handset and the iD Mobile app.
  • March 31, 2024
@Kash I have an IPhone, unfortunately ID were unable to help, it appears ID have not enabled IPhone users to be able to change the APN and looking at others with the same problem the only solution is to leave ID to be able to use it in France
  • 8128 replies
  • April 4, 2024
Hi @Benble
  • August 21, 2024
21/08/24
I've just had the same issue with my Android phone not being able to roam in France. I tried everything like resetting the network settings, turning phone off/on, disabling Sim....
Eventually resolved it when I found a link to  resetting my APN details as per screenshot  below. It seems because I have a SIM only contract that the APN (Access Point Names) in advanced network settings was not set to ID correctly.
It now works perfectly with full 4G.
Good luck 🤞
  • 8083 replies
  • August 27, 2024
Hi @DJS31,
Glad to hear that this is resolved and thanks for posting your fix.
Andy Wong
  • September 23, 2024
I’ve tried all the above and I still can’t get data roaming in France. I have an iPhone 15 pro max.
  • 8128 replies
  • September 26, 2024
Hi @Andy Wong
A network settings reset hasn’t worked?
Are calls and texts working?
Have you tried manually connecting to other networks for a few minutes and then back to either;
Orange
Free Mobile
BYTEL or BOUYGTEL
  • December 15, 2024
Back in France again and still same problem, reset does not work, brother has the same ID contract and his is working fine, has ID got a solution to why some I phones don’t work in France yet?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • December 15, 2024
@Benble
Have you enabled roaming on your account prior to leaving? Granted you’re an iPhone user (Android myself), but is roaming also turned on on your phone?
In my case I changed my phone from auto network connection type to manual. Scanned all available and picked one that way. So maybe give that a go and if iD’s roaming partners are in alphabetical try picking the 2nd or 3rd on the list? If this works remember you would need to manually connect after switching the phone off. Once you’re back also remember to switch the connection back to auto.
  • 3509 replies
  • December 16, 2024
Hey there ​@Benble, sorry to hear that. Please raise this with our live-chat team ASAP so they can troubleshoot and raise to our technical team if needed please:
