Help woth network connection
  • September 23, 2026
  • 28 views
On Monday 21st September I activated my switch to ID using an eSIM and PAC code transfer to be done today but I have not yet got my connection with ID. My number has changed to my old number on the app but I cannot get connection on my phone to the network.
    Hosai W
    Hi ​@Stewart1987
    I'll speak to you there.
    Hosai
    Having the same problem and can’t seem to get any answers that help
    Hi ​@Adiebady1.
    Thank you for your post. I am sorry to hear that your switch also hasn't completed smoothly on your end.
    Please try the following network reset steps depending on your device:
    For Android:
    Open Settings
    Tap General management
    Tap Reset
    Tap Reset network settings
    For iPhone:
    Go to Settings
    Tap Phone
    Tap My Number
    Delete the old number
    Enter the new number using the keypad
    Tap Save
    Go to Settings > Messages and turn off iMessage
    Go to Settings > General > Reset
    Tap Reset Network Settings
    Once your iPhone restarts, go back to Settings > Messages and turn iMessage back on, this should let it recognise the new network and verify properly.
    Please give your phone a restart after these steps if you haven't already, as that often helps it pick up the new network registration.
    Marquerita
    The iD Mobile Team
