Jun 12, 2026 6:27 AM UTC
i keep having problems receiving phone calls (and occasionally making them too)
every few days, I find my phone unable to receive phone calls and sometimes even make them.
it is usually solved by turning the phone off and on again but it is super annoying as it happens so often
Jun 13, 2026 4:15 PM UTC
Hi ​@cosnick365,
We're sorry to hear about the issues you've been experiencing with your coverage.
We appreciate how frustrating it can be when the service you're receiving doesn't match what you'd expect, particularly if the coverage checker is showing strong coverage in the areas where you're having problems.
As a first step, we'd recommend checking the coverage checker again to see if there are any reported issues or maintenance affecting the locations concerned: https://www.idmobile.co.uk/help-and-support/coverage-and-networks/network-coverage-checker
If the issue persists, please contact our Live Chat team so they can investigate further and check whether there are any network-related issues affecting your service: https://www.idmobile.co.uk/live-chat
They'll be able to review your account and discuss any available options based on the outcome of their investigation.
Jun 13, 2026 4:33 PM UTC
Still up and down (and sometimes I can’t even make/receive phone calls or even whatsup calls.  I don’t see any issues or maintenance in the location I am in…
If it doesn’t get better I will try the live chat
Jun 14, 2026 9:42 AM UTC
Hi ​@cosnick365,
Thanks for letting us know, what we can suggest is testing out a replacement SIM. Our live chat team would be happy to assist you in getting that done.
Jun 19, 2026 3:29 PM UTC
I occasionally keep getting that problem and have to turn off phone 2 or 3 times before it is sorted…
also unable to receive sms from abroad (that is since I switched to my old number)
Hosai W
Jun 23, 2026 9:17 AM UTC
Hi ​@cosnick365,
Thank you for getting in touch with us, please ensure that the number displayed in the app is starting with +44 instead of 0.
Hosai
Jun 23, 2026 3:23 PM UTC
That is correct
That was correct
Jun 25, 2026 9:49 AM UTC
Hi ​@cosnick365,
Thanks for your response.
Could you please confirm whether you've had the opportunity to test a replacement SIM card, as previously recommended? This will help us determine whether the issue is related to the SIM itself or if further investigation may be required.
Jun 25, 2026 9:54 AM UTC
When I joined id mobile I had an eSIM and I switched to a SIM card and didn’t improve things
Jun 28, 2026 3:46 PM UTC
Hi ​@cosnick365,
We're sorry to hear that switching from an eSIM to a physical SIM hasn't resolved the issue.
As you've already tried both types of SIM, we'd recommend contacting our Customer Service team via Live Chat. They'll be able to raise a technical request with our network team so they can investigate the issue further.
We hope this gets resolved for you as quickly as possible.
