Mar 5, 2026 7:36 PM UTC
im not receiving incoming calls
I’m not receiving any incoming calls
    Mar 5, 2026 9:12 PM UTC
    Make sure that VoLTE is enabled on your device.
    Mar 6, 2026 2:39 AM UTC
    I’m on a iPhone 16c so it’s not that
    Owethu M
    Mar 6, 2026 2:08 PM UTC
    Hi ​@StephenGGG
    Please check if your mobile number is correct under settings.
    1. Open Settings → Phone → My Number.
    2. Update the number to the one you wish to keep. Note that it may not save immediately.
    3. If the change does not save, please follow these steps:
    • Open the Settings app and tap General.
    • Scroll to the bottom and tap Reset.
    • Select Reset Network Settings, enter your passcode if prompted, and confirm the reset.
    This process should help ensure your number is updated correctly.
    -Owethu
    Mar 6, 2026 7:17 PM UTC
    Ive done that and still all incoming calls are going straight to voicemail
    Kwanele Z
    Mar 8, 2026 9:57 AM UTC
    Hi ​@StephenGGG ,
    I'll speak to you there.
    Kwanele
