Jul 1, 2026 10:38 AM UTC
incoming calls issue
Hi. I have set my phone up and for some reason I’m not able to receive any incoming calls going straight to voice mail but outgoing calls not an issue. What should I do
    Jul 2, 2026 4:36 PM UTC
    Hi ​@Angelo88,
    We're sorry to hear you're having trouble receiving incoming calls.
    If you can make outgoing calls but all incoming calls are going straight to voicemail, please try the following:
    For iPhone:
    • Restart your phone.
    • Turn Airplane Mode on for 30 seconds, then turn it off.
    • Check that Do Not Disturb or Focus Mode isn't enabled.
    • Go to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
    For Android:
    • Check that Do Not Disturb is turned off.
    • Go to Settings > General Management or System > Reset > Reset Network Settings.
    If the issue continues after trying the above, please contact our Customer Service team via Live Chat so they can investigate further and, if necessary, raise a technical ticket.
