Loss of signal - iPhone 17 Pro Max
Hi, I recently switched to ID Mobile and I get relatively consistent loss of signal throughout the day, I live in a city centre which is pretty built up and has many 5G towers and signal lines so not sure as to why this is ? Any help?
    Hi ​@Mal247.
    Thank you for your post. I am sorry to hear you’re experiencing signal drops after switching to iD Mobile.
    Even in city centres with strong 5G coverage, signal can sometimes be affected by factors like building density (walls, glass, steel structures), network congestion at busy times, or how your device is connecting between different signal types (3G/4G/5G) as you move around.
    A few things you can try that often help improve stability:
    Turn Airplane Mode on and off to refresh the connection
    Make sure 5G/4G is enabled in your network settings
    Restart your phone
    If the issue continues, we can run a full network check on your line and location and investigate further here: https://www.idmobile.co.uk/help-and-advice/coverage.  or you can reach out to us via live chat here: https://www.idmobile.co.uk/live-chat
     so we can take a closer look for you.
    Marquerita
    The iD Mobile Team
