Gary Richardson
Jul 30, 2026 12:36 PM UTC
network issue PE20 3QU been a issue for past 6 months ID mobile saying there is a issue
Can anyone say when the signal will be improved in the area as this has been going on for the past 6 months
which seams to be a Three signal issue as my wife is with Smarty on Three and has the same issue
it states it on the ID mobile app there is a issue
its a shame cos if it continues need to look at another provider which I don’t want to do???
thanks
Anneline M
Jul 31, 2026 1:27 PM UTC
Hi ​@Gary Richardson,
We’re sorry to hear about the issue you’re experiencing with the coverage in your area.
Please use the following link to check the coverage in your area: https://www.idmobile.co.uk/help-and-advice/coverage or try to reinsert your SIM, or try your SIM in another phone. This will determine whether the issue is with the handset or with the SIM card itself.
You can also try doing a network reset by following these steps:
For Android:
Open Settings and then tap General management. Tap Reset, and then tap Reset network settings.
For iPhone:
1. Go to General, scroll down and click reset or transfer iPhone.
2. Reset
3. Reset Network Settings.
4. Once the iPhone is open.
5. Go to Settings
6. Messages Turn ON iMessage.
7.This will recognize the new sim and have it verified.
Anneline
Gary Richardson
Jul 31, 2026 2:43 PM UTC
Zandile M
Aug 3, 2026 4:47 PM UTC
Thank you for the update.
Please try the above steps as the coverage issue is complete in your area.
Zandile M
The iD Mobile Team
