Not being able to send text messages using a samsung 22+
  • April 6, 2026
  • 63 views
I have a samsung 22+ . Since moving to id mobile i can receive text messages but i cannot send them. I always get a message pop up saying waiting to connect and check options- why is this
    Hi ​@mevq,
    I’m really sorry you’re having trouble sending texts since joining iD Mobile, I can appreciate how frustrating that must be, especially when receiving messages is working fine.
    This issue is usually caused by a settings or network connection problem on the device, so it’s worth trying a few quick troubleshooting steps:
    Check your SMS settings:
    • Go to Messages app
    • Tap Settings → More settings → Text messages
    • Check the Message Centre number is set correctly (this is essential for sending texts). If it’s missing or incorrect, Live Chat can provide the correct one.
    Reset network settings (recommended):
    • Go to Settings → General management → Reset
    • Tap Reset network settings
    • Restart your phone afterwards
    Hope this helps and you get it sorted quickly!
