Oct 23, 2026 10:27 AM UTC
Outgoing calls keep failing incoming calls go to answerohone even whrn bars on my phine.
Help I basically cannot use this as a phone!
    Oct 26, 2026 11:30 AM UTC
    Hi ​@Jongov23,
    I'm sorry to hear you're having issues with your calls.
    Please try the following troubleshooting steps:
    1. Restart your phone.
    2. Turn Airplane Mode on for 30 seconds, then turn it off again.
    3. Check that your phone software is up to date.
    4. Make sure Network Selection is set to Automatic.
    5. Try turning 4G Calling/VoLTE off and then back on.
    6. Reset your network settings.
    7. If you're using a physical SIM, remove it and reinsert it.
    8. Check the coverage in your area using our coverage checker: https://www.idmobile.co.uk/help-and-support/coverage-checker
    9. If possible, try your SIM in another handset to see if the issue follows the SIM or stays with the phone.
    If the issue continues, please let us know:
    • Your postcode
    • The make and model of your phone
    • Whether texts and mobile data are working
    For your security, please don't post any personal or account information such as your mobile number, account number, address, email address, or payment details, as this is a public forum.
    Jongov23Author
    Oct 26, 2026 1:26 PM UTC
    No this still does not work. Cannot even make calls when indoors and have wifi and wifi calling on! Total nighmare.
    Oct 27, 2026 3:13 PM UTC
    Hi ​@Jongov23,
    I'm sorry to hear that the issue is still ongoing.
    As you've already tried the troubleshooting and you're unable to make calls even when connected to Wi-Fi with Wi-Fi Calling enabled, this will need further investigation from our side.
    Please contact our Live Chat team and explain that you've already completed the troubleshooting steps and that the issue remains unresolved. They'll be able to investigate further and, if necessary, raise a ticket for the relevant team to review.
    You can contact them here: https://www.idmobile.co.uk/live-chat
