poor signal no 5g . voice signal sounds like a 50s radio wirh crosstalk banging sound in backgrounds
  • October 14, 2025
  • 21 views
when i make a call or recive one i get banging noise afterbthenperson as finished talking.  and sonebtimeni can hear myself on the line like a echo.  the signal is 4g but the voice quality is rubbish ... i live in a villige only 50meters away from the mast.  the internet is slow with only 20mb download speeds on 4g.. there is no 5g service at all ! .  using 3 as your backbone i thpught this would be better than this  !!!!!!
    The iD network partner Three UK has shutdown their 3G mobile network infrastructure for most places in the UK, ​@o0ohappyo0o.
    Is the mast 50 meters away operated by Three UK?
    Have you tried using the iD WiFi calling service at home?
    Forum member (non-iD).
    Hi ​@o0ohappyo0o
    I do apologise that you're unable to use the services to their full capacity in your area and that things have been running slowly for you.
    Could you please try the steps below and let me know if there’s any improvement?
    For Apple devices:
    Go to Settings
    Tap Mobile Service
    Tap Network Selection
    Toggle Automatic off
    Select iD Mobile from the available networks
    Swipe up from the bottom of the screen to return to the home screen
    Wait a few minutes and try using the services again
    For Android devices:
    Swipe down from the top of the screen to open the notification panel
    Tap the Settings icon
    Go to Connections
    Select Mobile Networks
    Turn off Select Automatically
    Choose iD Mobile from the list
    ​@andewhite Thank you for the above as well.
    Michael Z
