signal dropping in doors and outdoors
Over last be 2/3 months my phone signal keeps dropping where calls have ended or l have no signal in areas where l used to get signal
    Hi ​@B wilk20019.
    Thanks for letting us know, and sorry to hear you've been experiencing this, a change in signal or dropped calls in areas that used to work fine can be frustrating, especially over a few months.
    Here are a couple of quick things that may help narrow down the cause:
    • Please check our coverage checker for your specific area: https://www.idmobile.co.uk/help-and-advice/coverage.
    • Try removing and reinserting your SIM card
    • If possible, try your SIM in another phone; this will help determine whether the issue lies with the handset or the SIM itself.
    Marquerita
    The iD Mobile Team
    Have been with ID for over two years and had no issue, yet is now over last 3 months not gettimg signal in areas l used to her a signal and calls constantly dropping
    Hi ​@B wilk20019,
    I’m sorry to hear that you’ve recently started experiencing poor signal and dropped calls, especially after having no issues with the service previously.
    As this has been ongoing for around three months, please contact our Live Chat team so they can check the coverage and service in your area, review your account and investigate the issue further. https://www.idmobile.co.uk/live-chat
