signal problems?
My android phone calls are not connecting to anybody. Not even 4444.  What's app is connecting with calls and getting messages. Tried everything that's been suggested. SIM out SIM in. Bluetooth reset. Wife has just checked hers and same. Checked online and it says no problems.
    Noz1954Answer
    Hi ~Marquerita
    I went to Currys last night and replaced it there.
    Seems to be working well now.
    Thank you for information.
    Hi ​@Noz1954.
    Thank you for your post.
    I’m sorry to hear you’re both experiencing issues with making calls.  I understand how concerning that must be.
    Based on what you’ve described, I would recommend trying a replacement SIM, as this can often resolve calling issues like the ones you’re experiencing. You can pick one up from your nearest Currys store.
    Alternatively, you can contact us directly via Live Chat here: https://www.idmobile.co.uk/live-chat and we can arrange for a replacement SIM to be sent out to your home.
    If the issue continues after that, our team will be able to investigate further for you.
    ~Marquerita
    Noz1954AuthorAnswer
    Hi ~Marquerita
    Owethu M
    Hi ​@Noz1954,
    Thanks for letting us know I’m really glad to hear everything’s working properly now after getting the replacement sorted 😊
    It does sound like the issue may have been related to the original SIM or device, so it’s great that’s now resolved.
    If you do notice anything similar again or need any further help, don’t hesitate to reach out we’re always here to help.
    Thanks again for the update! 👍
    Owethu
