why is my call quality terrible when others call me but not when i call them back.
  • October 14, 2025
  • 84 views
So when I make calls they’re great quality but any calls I receive sound terrible and hard to understand. This becomes hard when it’s someone like the doctor calling.
    Hi ​@Csab ,
    Please confirm the make and model of your device for and when did this issue start? It also helps to reset network settings.
    -Isa🎀
    CsabAuthor
    hi, so it’s a iPhone 15 pro. And the problems have been for 2 years I just did not receive calls often and only just realised it’s on my end that’s the issue
    Hi ​@Csab
    Are you hearing a crackling sound whenever you receive a call? If so, the issue might be with the earpiece at the top of your phone, it could be faulty or damaged.
    Michael Z
    CsabAuthor
    Hi ​@Csab
    Michael Z
    I can send calls and hear perfectly it’s just when I receive them. Even on Bluetooth this happens
    Have you tried a replacement iD SIM for your iPhone 15, ​@Csab?
    A faulty or damaged SIM can result in mysterious issues with mobile network services.
    Forum member (non-iD).
    For some reason I brought my iPhone 17 pro max and the top earpiece speaker makes a rattling sound
    Hi ​@Sammz,
    I'm sorry to hear that your new iPhone 17 Pro Max appears to have an issue with the earpiece speaker.
    If you're hearing a rattling or buzzing sound from the top speaker during calls, media playback, or at higher volumes, we'd recommend having the device inspected.
    As the handset was purchased recently, you can:
    • Visit your nearest Currys store if the phone was purchased through Currys.
    • Contact Apple Support or visit an Apple Store for a diagnostic check.
    They'll be able to assess whether the noise is being caused by a hardware fault and advise on the available repair or replacement options.
