Jun 6, 2026 5:13 PM UTC
i have upgrade with ID mobile and kept the same sim will my number stay the same please
I have upgraded with ID mobile and have the same SIM, will I keep the same number
    Decembersangel72
    Gold Contributor
    Jun 7, 2026 12:18 AM UTC
    Hi ​@Teepee1979
    Yes, you will keep your number, but only if you process an official upgrade of your existing contract rather than purchasing a brand new plan independently. iD Mobile does not allow you to transfer numbers internally between two separate, active accounts
    https://www.idmobile.co.uk/upgrades!--tgqphd|[]-->!--tgqphd|[]-->!--tgqphd|[]-->
    Hope this helps x
    Decembersangel72
    Gold Contributor
    Gold Contributor
    Hi ​@Teepee1979
    Hope this helps x
    Lamiya C
    Jun 8, 2026 12:34 PM UTC
    Hi ​@Teepee1979,
    Yes, in most cases, if you’ve upgraded with iD Mobile and kept the same SIM, you’ll keep the same phone number.
    An upgrade is just a change of handset/plan, so your number stays linked to your existing account.
    You can also confirm by:
    Calling someone and asking what number shows
    Or checking in Settings → About Phone → My Number
    Lamiya
