Upgrading to keep same mobile, do I click 'physical sim' or 'esim'
Hi all, apologies I need constant reassurance before doing anything! I have researched and if understood correctly, as long as i click Upgrade whilst in my account and browse the deals,I will keep my mobile number.
When I get to checkout, I am confused as to which sim option to pick. Should I be clicking ‘physical sim’ which has the description - “keep using your current sim card in your new phone” which I imagine means I keep my number as all I need to do is remove the sim from my current phone and pop it in the new handset?
Thanks in advance!
    WelshPaulAnswer
    ​@SarahJay  You are correct in thinking this however if you call sales between 9am to 6pm Mon To Fri on +44 20 7139 1397 the will definitely help you make the correct decision.
    Joe 🙂
    Hi Joe, thanks for answering but this doesn’t really answer my question, do I pick physical sim or esim at check out?
    Choose your preferred option. For a physical SIM, select “Physical SIM”. For an eSIM, select “eSIM”. If you’re upgrading, your existing number will be used with your chosen option.
    SarahJayAuthor
    Just want to clarify subject title was meant to say ‘keep mobile number’, I’m looking to get a new handset :)
    JoeKing
    Silver Contributor
    Silver Contributor
    November 4, 2025
    Joe 🙂
    SarahJayAuthor
    Joe 🙂
    WelshPaulAnswer
    Joe 🙂
    Hi ​@SarahJay
    I am so sorry to hear of any issues that you may be facing regarding your upgrade. Please see the below steps to upgrade either to a handset or SIM-only plan:
    SIM ONLY
    Please follow the steps below:
    1. From dashboard, scroll down and tap on "view all upgrade deals".
    2. On the next page, select the box "SIM only deals".
    3. Scroll down and tap on "choose this plan" next to the plan you wish to proceed with.
    4. On the next page, tap on "continue" and follow the steps to complete the order. A card verification will be required. After completing this step, tap on "place order".
    5. You will receive an order reference number at the end.
    HANDSET
    2. Scroll down and tap on "choose this plan" next to the plan you wish to proceed with.
    3. On the next page, tap on "continue" and follow the steps to complete the order. A card verification will be required. After completing this step, tap on "place order".
    4. You will receive an order reference number at the end.
    Gemma
    iD Social Media
