Del Wico
Jan 9, 2026 7:36 PM UTC
Can I use my mobile data and phone home from Poland and Kefalonia (greece) if so will i be charged?
I'm trying to understand the roaming beyond article. It has the destinations on the list we are travelling to but I don't understand if I will be charged and if so how much? & if I am even able to use my mobile data or call the UK from Poland and Kefalonia? Can someone shed some light please? Or does it go on what plan you have? Thanks!
    MZone
    MZoneAnswer
    Jan 9, 2026 11:29 PM UTC
    Yes you can
    • Use your remaining inclusive data, up to 30GB.
    • Call or text the UK (standard landline and mobile numbers) with remaining inclusive minutes and texts
    • Receive incoming calls and texts from any country
    As Kefalonia is close to Albania which is not included you have to be careful you don’t connect to an Albanian network or you will be charged. I suggest you set a spend cap of £0 via the app to avoid any unwanted charges.
    MZone
    MZoneAnswer
    Yes you can
    Del Wico
    Del WicoAuthor
    Jan 10, 2026 7:01 AM UTC
    Thank you so much for your help and explanation. I really appreciate that!
    Jan 10, 2026 9:52 AM UTC
    Hi ​@Del Wico,
    As ​@MZone has mentioned, you are able to use the roaming data, however if you are making use of a ship, ferry or cruise you may be charged for international roaming. We do recommend ensuring that your bill cap is set to £0.00 to ensure that you do not get any unwanted charges. You can do so by following the below steps:
    To change your iD Mobile bill cap, log in to the iD Mobile app or My Account online, go to the 'Bills' section, find 'Manage bill cap', and use the slider or input field to set your new amount, then save changes; you can adjust it anytime for out-of-bundle spending. If you can't access your account, contact iD Mobile directly
